Here is the changelog for 2.1.5.
NOTE: This changelog represents cumulative changes since version 2.1b.
Version 2.1.4 did not have a changelog, so changes in that version
(that still exist in 2.1.5) will be listed here.
PowerHome code has been updated to the latest version of PowerBuilder
libraries (version 12.5).
Database engine has been upgraded to SQL Anywhere 11 from Adaptive
Server Anywhere 7.
New Insteon engine with full I2CS support. All previous Insteon bugs
should be resolved. New Insteon tables hold all published Insteon device
types and will be auto-added to the Insteon Types table during auto
discovery. NOTE that some I2CS devices may be firewalled and not
readily "discovered" by programatic methods. See discussion about this
issue in "FAQs-Setting up Thermostats in PH 2.1.5" for more information
on how to resolve this, should it be a problem.
I2CS Thermostats now fully supported. NOTE: PH Version 2.1.5 on,
uses a significantly different approach to Thermostat support than
previous PH Versions did. See Help File "FAQs-Setting up Thermostats in
PH 2.1.5" for detailed information.
New Options window for Insteon devices. Allows for extended programming
of various Insteon devices.
The Options window is accessed via the Options button in the Insteon Explorer Devices tab.
Insteon KPL config has been updated to use the Insteon KPL configuration
commands (instead of the old peek/poke memory locations). KPL tab has
been removed from Insteon Explorer and added to the new Insteon Options
window. Peek/Poke commands still available for legacy devices.
Added support for Insteon GarageHawk.
Changed most timing operations within PowerHome to a single background
multi-threaded object. Should solve contention issues between multiple
components.
All references to MSCOMM32 (Microsoft COMM control) have been removed.
Serial port controls have all been replaced with COMM32 control. Allows
COM ports 1 thur 255.
All references to MSWINSCK (Microsoft Winsock control) have been
removed. All socket controls have been upgraded with Catalyst 8
controls.
All plugins have been brought up to current controls (serial/winsock)
and current codebase (PowerBuilder plugins are 12.5). This should solve
the problems people were having with the PH_CID plugin.
Eventlog and weblog tables have been moved to their own database
(phlogs.db). No more corrupt databases due to the eventlog and weblog
growing to very large sizes.
Eventlog report has been rewritten as a background thead with the option
to cancel retrieval. No more hanging of PowerHome when retrieving very
large logs. Start reviewing log immediately while retrieval continues in
the background.
New log options. Resume Macro will fire when a macro is resumed from
waiting. Verbose macro will cause the existing Macro and the new Resume
Macro to also display in the Event Log the values of
[LOCAL1] thru [LOCAL10] and [TEMP1] thru [TEMP10]. Now you'll be able to
get a better idea of what is going on with your macros until the macro
debugger is released.
These posting parameters are accessed in the PowerHome Explorer>Setup>Logs object.
New Analog device types. Dedicated analog types for Insteon GarageHawk,
IOLinc, EZRain/EZFlora, Insteon Responder Group (eliminates need for
virtual Insteon devices), etc. Allows for complete control of these
devices without having to do any scripting.
Thermostats table has been deprecated. Insteon and Elk Thermostats have
their own individual device types (Temperature, Cool SetPoint, etc) in
the Analog I/O table. While this is a substantial improvement,
unfortunately it means that prior Thermostat coding in earlier versions
of PH will have to be re-visited in order to obtain full benefits. See
Help File "FAQs-Setting up Thermostats in PH 2.1.5" for detailed
information.
Timed Events routine has been reworked to solve problem with
disappearing timed events. Now using update instead of Delete/Insert
during timed event processing.
New labeling system added. Add one or more user defined labels to
devices, macros, triggers, etc. Filter by label in PowerHome Explorer
and Device Status screen. Group devices, formulas, macros, etc. together
logically.
New 1-wire controller type. Support 1-wire devices directly within
PowerHome. This controller runs in a separate thread due to the overhead
of 1-wire communications.
New generic parallel port controller type.
New CM15A controller type. Supports both PLC and RF capabilities of this
device.
New Insteon SmartLinc/NetLinc/Hub controller type. Connect directly to
Insteon IP capable PLM's without having to use a virtual serial
port.
Virtual Serial Port plugin updated to use the latest version 7.2 of
Eltima controls. Plugin rewritten to be an activex EXE (rather than OCX)
for better reliability and stability.
Reworked execution queue to support priority and top items. See
ph_postexequeue function.
Direct control and status of Controllers from the PowerHome UI. Under
Help->About->Controllers, you'll be able to see the connect status
of the controllers as well as change the status.
New options to select lines in a macro and delete, cut, copy, or paste
them to other macros (or the current macro).
To use this feature CTRL-Click on any Macro line of code and the entire line will be selected. Additional CTRL-Clicks will select additional individual lines of code, while a Shift_Click will select all lines between the first and last Click.
Once your Selection is made, Right-Click the mouse anywhere in the Macro and a context menu will appear. Choose the "Selected" menu item and the desired action.
If you Cut/Copy, you can Paste it in this or another Macro. After you select a target row, you can then Paste and the clipboard content will be Inserted at that location. It inserts, not overwrites, so following lines will be moved down to make room.
New regular expression capability (available in functions ph_regex2, ph_regexdiff2, and ph_regexsnap2). This regular expression syntax is the same as VB and offers many more options than the regex functionality in Scintilla. Reference this website for very detailed documentation concerning this syntax: http://www.regular-expressions.info/vb.html Webserver and Socket Server rewritten to eliminate contention
errors.
Webserver has additional security options (cookie) and now supports
SSL.
SMTP email functions have all been rewritten to use Catalyst SMTP
control vs a raw socket. Improved stability and performance. New
ph_sendsmtpemailasync function allows you send email asynchronously
rather than holding up PowerHome execution waiting for the email
function to return.
Numerous bugfixes, critical error fixes, and tweaks throughout. Too many
to list. Since alot of the base code is completely new, please re-report
any bugs or critical errors as they occur.
New Plugins:
Virtual Serial Port, Roku, Directory Monitor, Windows Lock Monitor,
AVTech DVR control, Windows Monitor, Growl Control, ODBC Database
Control, Windows Power Monitor, URL Scraper
New Functions:
d2h, h2d, h2s, ph_base64decode1, ph_convertir, ph_ctlrcontrol,
ph_decrypt, ph_deletetimedevent, ph_encrypt, ph_fill, ph_formulabtnparm,
ph_funcdef, ph_funclist, ph_getdevicestat, ph_getdeviceval,
ph_getlasterrorstring, ph_getmd5hash, ph_getmd5hash1, ph_getmtret,
ph_getothercounter, ph_getsyspwrstat, ph_gettstat, ph_gettstat_s,
ph_geturl1, ph_geturlviaproxy1, ph_getvarsub, ph_htmlescape1,
ph_insteonprodlistimport, ph_insteonrawext, ph_insteonwithret1,
ph_insteonwithretext, ph_insteonwithretext1, ph_isssrunning,
ph_iswslocked, ph_latlongdist, ph_locatehandle1, ph_lockworkstation,
ph_minutestostring, ph_not, ph_number, ph_pad, ph_ping1,
ph_postexequeue, ph_posturl1, ph_posturlviaproxy1, ph_random, ph_regex2,
ph_regexdiff2, ph_regexsnap2, ph_retrievevars, ph_runasuser1,
ph_runsync1, ph_saveurl1, ph_saveurlviaproxy1, ph_sendsmtpemailasync,
ph_sendsmtpemailfileasync, ph_setdeviceval, ph_setothercounter,
ph_settemps, ph_settstat, ph_shutdown, ph_snapxml, ph_split,
ph_storevars, ph_sumnum, ph_timedeventsinfo, ph_trim, ph_urlescape,
ph_varsub, ph_x10other, s2h
Changed Functions:
ph_devicebtn, ph_getdigitalstat, ph_getinsteonctrl, ph_getinteonstat,
ph_getvar_d, ph_getvar_dt, ph_getvar_n, ph_getvar_s, ph_getvar_t,
ph_insteonctrl, ph_modifytimedevent, ph_rtne, ph_runasuser,
ph_sendsocketdata1, ph_setanalogout, ph_webaddblob, ph_webds
